t1-linear - Affine registration of T1w images to the MNI standard space¶
This pipeline performs a set of steps in order to affinely align T1-weighted MR images to the MNI space using the ANTs software package [Avants et al., 2014]. These steps include: bias field correction using N4ITK [Tustison et al., 2010]; affine registration to the MNI152NLin2009cSym template [Fonov et al., 2011, 2009] in MNI space with the SyN algorithm [Avants et al., 2008]; cropping of the registered images to remove the background.
This pipeline was designed as a prerequisite for the `extract and deep learning classification algorithms presented in [Wen et al., 2020].
Dependencies¶
If you only installed the core of Clinica, this pipeline needs the installation of ANTs on your computer. You can find how to install this software package on the third-party page.
Running the pipeline¶
The pipeline can be run with the following command line:
clinica run t1-linear [OPTIONS] BIDS_DIRECTORY CAPS_DIRECTORY
where:
BIDS_DIRECTORYis the input folder containing the dataset in a BIDS hierarchy.CAPS_DIRECTORYis the output folder containing the results in a CAPS hierarchy.
On default, cropped images (matrix size 169×208×179, 1 mm isotropic voxels) are
generated to reduce the computing power required when training deep learning models.
Use the option --uncropped_image if you do not want to crop the image.
Note
The arguments common to all Clinica pipelines are described in Interacting with clinica.
Tip
Do not hesitate to type clinica run t1-linear --help to see the full
list of parameters.
Outputs¶
Results are stored in the following folder of the CAPS
hierarchy:
subjects/<participant_id>/<session_id>/t1_linear with the following outputs:
<source_file>_space-MNI152NLin2009cSym_res-1x1x1_T1w.nii.gz: T1w image affinely registered to theMNI152NLin2009cSymtemplate.- (optional)
<source_file>_space-MNI152NLin2009cSym_desc-Crop_res-1x1x1_T1w.nii.gz: T1w image registered to theMNI152NLin2009cSymtemplate and cropped. <source_file>_space-MNI152NLin2009cSym_res-1x1x1_affine.mat: affine transformation estimated with ANTs.
Going further¶
You can now use the ClinicaDL framework presented in [Wen et al., 2020] for classification or registration quality check based on deep learning methods.
Describing this pipeline in your paper¶
Example of paragraph
These results have been obtained using the t1-linear pipeline of Clinica
[Routier et al., 2021;
Wen et al., 2020].
More precisely, bias field correction was applied using the N4ITK method
[Tustison et al., 2010].
Next, an affine registration was performed using the SyN algorithm
from ANTs [Avants et al., 2014]
to align each image to the MNI space with the ICBM 2009c nonlinear symmetric template
2009].
(Optional) The registered images were further cropped to remove the background
resulting in images of size 169×208×179, with 1 mm isotropic voxels.
Tip
Easily access the papers cited on this page on Zotero.
