Introduction
Partial volume correction (PVC)
To correct for partial volume effects, several PVC algorithms exist and are implemented in the PETPVC toolbox.
To perform PVC (compulsory for pet-surface, optional for pet-volume), you will need to specify in a TSV file the full width at half maximum (FWHM), in millimeters, of the point spread function (PSF) associated with your data, in the x, y and z directions.
For instance, if the FWHM of the PSF associated with your first image is 5 mm along the x and y axes, and 6 mm along the z axis, the first row of your TSV file will look like this:
participant_id    session_id     acq_label     psf_x    psf_y    psf_z
sub-CLNC0001      ses-M00        fdg           5        5        6
sub-CLNC0001      ses-M00        av45          4.5      4.5      5
sub-CLNC0002      ses-M00        fdg           5        5        6
sub-CLNC0003      ses-M00        fdg           7        7        7
Since the PSF depends on the PET tracer and scanner, the participant_id, session_id, acq_label, psf_x, psf_y and psf_z columns are compulsory.
The values in the column acq_label should match the value associated to the acq key in the BIDS dataset. For example in the following BIDS layout the values associated would be fdg and av45:
bids
└─ sub-CLNC0001
    └─ <ses-M00
        ├─ sub-001_ses-M00_task-rest_acq-av45_pet.nii.gz
        └─ sub-001_ses-M00_task-rest_acq-fdg_pet.nii.gz
Reference regions used for intensity normalization
In neurology, an approach widely used to allow inter- and intra-subject comparison of PET images is to compute standardized uptake value ratio (SUVR) maps. The images are intensity normalized by dividing each voxel of the image by the average uptake in a reference region. This region is chosen according to the tracer and disease studied as it must be unaffected by the disease.
Clinica v0.3.8 introduces the possibility for the user to select the reference region for the SUVR map computation.
Reference regions provided by Clinica come from the Pick atlas in MNI space and currently are:
  • pons: 6 mm eroded version of the pons region
  • cerebellumPons: 6 mm eroded version of the cerebellum + pons regions
  • pons2: new in Clinica v0.4
  • cerebellumPons2: new in Clinica v0.4
In Clinica v0.4 two new versions of these masks have been introduced: pons2 and cerebellumPons2. Indeed we wanted to improve the reference regions mask to better fit the MNI152NLin2009cSym template used in linear processing pipelines. The new masks still come from the Pick atlas but with a different processing: we decided to first truncate the mask using SPM12 tissue probability maps to remove voxels overlapping with regions outside the brain (bone, CSF, background...). Then, we eroded the mask using scipy binary_erosion with 3 iterations.
Tutorial: How to add new SUVR reference regions to Clinica?
It is possible to run the pet-surface and pet-volume pipelines using a custom reference region.
  • Install Clinica following the developer instructions ;
  • In the <clinica>/clinica/utils/pet.py file, modify the following two elements:
    • The label of the SUVR reference region that will be stored in CAPS filename(s):
    LIST_SUVR_REFERENCE_REGIONS = [
        "pons",
        "cerebellumPons",
        "pons2",
        "cerebellumPons2"
    Simply define a new label that will be your new SUVR reference region. LIST_SUVR_REFERENCE_REGIONS is used by all command-line interfaces so you do not need to modify the pipelines' CLI to make this new region appear.
    • The path of the SUVR reference region that you will use:
    def get_suvr_mask(suvr_reference_region):
        """Get path of the SUVR mask from SUVR reference region label.
        Args:
            suvr_reference_region: Label of the SUVR reference region
        Returns:
            Path of the SUVR mask
        import os
        suvr_reference_region_to_suvr = {
            "pons": os.path.join(
                os.path.split(os.path.realpath(__file__))[0],
                "resources",
                "masks",
                "region-pons_eroded-6mm_mask.nii.gz",
            "cerebellumPons": os.path.join(
                "resources",
                "masks",
                "region-cerebellumPons_eroded-6mm_mask.nii.gz",
            "pons2": os.path.join(
                "resources",
                "masks",
                "region-pons_remove-extrabrain_eroded-2it_mask.nii.gz",
            "cerebellumPons2": os.path.join(
                "resources",
                "masks",
                "region-cerebellumPons_remove-extrabrain_eroded-3it_mask.nii.gz",
        return suvr_reference_region_to_suvr[suvr_reference_region]
    In this example, the SUVR reference region associated with the cerebellumPons label is located at <clinica>/resources/masks/region-cerebellumPons_eroded-6mm_mask.nii.gz.
