Introduction¶
Partial volume correction (PVC)¶
To correct for partial volume effects, several PVC algorithms exist and are implemented in the PETPVC toolbox.
To perform PVC (compulsory for pet-surface
, optional for pet-volume
), you will need to specify in a TSV file the full width at half maximum (FWHM), in millimeters, of the point spread function (PSF) associated with your data, in the x, y and z directions.
For instance, if the FWHM of the PSF associated with your first image is 5 mm along the x and y axes, and 6 mm along the z axis, the first row of your TSV file will look like this:
participant_id session_id acq_label psf_x psf_y psf_z
sub-CLNC0001 ses-M00 fdg 5 5 6
sub-CLNC0001 ses-M00 av45 4.5 4.5 5
sub-CLNC0002 ses-M00 fdg 5 5 6
sub-CLNC0003 ses-M00 fdg 7 7 7
Since the PSF depends on the PET tracer and scanner, the participant_id
, session_id
, acq_label
, psf_x
, psf_y
and psf_z
columns are compulsory.
The values in the column acq_label
should match the value associated to the acq
key in the BIDS dataset.
For example in the following BIDS layout the values associated would be fdg
and av45
bids
└─ sub-CLNC0001
└─ <ses-M00
├─ sub-001_ses-M00_task-rest_acq-av45_pet.nii.gz
└─ sub-001_ses-M00_task-rest_acq-fdg_pet.nii.gz
Reference regions used for intensity normalization¶
In neurology, an approach widely used to allow inter- and intra-subject comparison of PET images is to compute standardized uptake value ratio (SUVR) maps. The images are intensity normalized by dividing each voxel of the image by the average uptake in a reference region. This region is chosen according to the tracer and disease studied as it must be unaffected by the disease.
Clinica v0.3.8
introduces the possibility for the user to select the reference region for the SUVR map computation.
Reference regions provided by Clinica come from thePick atlas in MNI space and currently are:
pons
: 6 mm eroded version of the pons region -
cerebellumPons
: 6 mm eroded version of the cerebellum + pons regions -
pons2
: new in clinicav0.4
cerebellumPons2
In clinica v0.4
two new versions of these masks has been introduced: pons2
and cerebellumPons2
. Indeed we wanted to improve the reference regions maks to fit more the MNI152NLin2009cSym template used in linear processing pipelines. The new masks still come from the Pick atlas but with a different processing: we decided to first truncate the mask using SPM12 tissue probablity maps to remove voxels overlapping with regions outside the brain (bone, csf, bachground...). Then we eroded the mask using scipy binary_erosion
with 3 iterations.
Tutorial: How to add new SUVR reference regions to Clinica?¶
It is possible to run the pet-surface
and pet-volume
pipelines using a custom reference region.
Install Clinica following the developer instructions ;
In the
<clinica>/clinica/utils/pet.py
file, modify the following two elements:- The label of the SUVR reference region that will be stored in CAPS filename(s):
LIST_SUVR_REFERENCE_REGIONS = [ "pons", "cerebellumPons", "pons2", "cerebellumPons2" ]
Simply define a new label that will be your new SUVR reference region.
is used by all command-line interfaces so you do not need to modify the pipelines' CLI to make this new region appear.- The path of the SUVR reference region that you will use:
def get_suvr_mask(suvr_reference_region): """Get path of the SUVR mask from SUVR reference region label. Args: suvr_reference_region: Label of the SUVR reference region Returns: Path of the SUVR mask """ import os suvr_reference_region_to_suvr = { "pons": os.path.join( os.path.split(os.path.realpath(__file__))[0], "..", "resources", "masks", "region-pons_eroded-6mm_mask.nii.gz", ), "cerebellumPons": os.path.join( os.path.split(os.path.realpath(__file__))[0], "..", "resources", "masks", "region-cerebellumPons_eroded-6mm_mask.nii.gz", ), "pons2": os.path.join( os.path.split(os.path.realpath(__file__))[0], "..", "resources", "masks", "region-pons_remove-extrabrain_eroded-2it_mask.nii.gz", ), "cerebellumPons2": os.path.join( os.path.split(os.path.realpath(__file__))[0], "..", "resources", "masks", "region-cerebellumPons_remove-extrabrain_eroded-3it_mask.nii.gz", ), } return suvr_reference_region_to_suvr[suvr_reference_region]
In this example, the SUVR reference region associated with the
cerebellumPons
label is located at<clinica>/resources/masks/region-cerebellumPons_eroded-6mm_mask.nii.gz
