Classification based on machine learning using scikit-learn¶
Clinica provides a modular way to perform classification based on machine learning. To build its own classification pipeline, the user can combine three modules based on scikit-learn [Pedregosa et al., 2011]:
- Input (e.g. gray matter maps obtained from T1-weighted MR images, FDG PET images)
- Algorithm (e.g. support vector machine, logistic regression, random forest)
- Validation (e.g. K-fold cross validation, repeated K-fold cross validation, repeated hold-out validation)
Prerequisites¶
You need to have performed the t1-volume
pipeline on your T1-weighted MR images and/or the pet-volume
pipeline on your PET images.
Dependencies¶
If you installed the core of Clinica, this pipeline needs no further dependencies.
Classification modules¶
Input¶
Two classes corresponding to the voxel-based and the region-based approaches are implemented in input.py
CAPSVoxelBasedInput
: all the voxels of the image are used as features.CAPSRegionBasedInput
: a list of values stored in a TSV file is used as features. This list corresponds to PET or T1 image intensities averaged over a set of regions obtained from a brain parcellation when running thet1-volume
and/orpet-volume
pipeline.
Note
The atlases that can be used for the region-based approaches are listed here.
Algorithm¶
Three classes corresponding to the machine learning-based classification algorithms are implemented in algorithm.py
DualSVMAlgorithm
: support vector machine (SVM) algorithm (input: all the data available or a kernel that can be pre-computed)LogisticReg
: logistic regression algorithm (input: all the data available)RandomForest
: random forest algorithm (input: all the data available)
Each algorithm implements a grid search approach to choose the best parameters for the classification by looking at the value of the balanced accuracy.
The area under the receiver operating characteristic (ROC) curve (AUC) is also reported.
The labels are automatically assigned based on the diagnoses_tsv
file.
Validation¶
Three classes corresponding to the validation strategies are implemented in validation.py
KFoldCV
: K-fold cross validationRepeatedKFoldCV
: repeated K-fold cross validationRepeatedHoldOut
: repeated hold-out validation
The input is the name of the classification algorithm used.
Running your pipeline¶
No matter the combination of modules chosen, the inputs necessary are:
caps_directory
: the folder containing the results of thet1-volume
and/or thepet-volume
pipeline (where TSV files are stored)subjects_visits_tsv
: the TSV file containing theparticipant_id
and thesession_id
columnsdiagnoses_tsv
: a TSV file where the diagnosis for each participant (identified by a participant ID) is reported (e.g. AD, CN). It allows the algorithm to perform the dual classification (between the two labels reported). Example of a diagnosis TSV file:
participant_id diagnosis
sub-CLNC0001 AD
sub-CLNC0002 CN
sub-CLNC0003 AD
sub-CLNC0004 AD
sub-CLNC0005 CN
group_label
: the label of the group of subjects studiedimage_type
: a value to set the modality studied (T1w
orPET
)output_dir
: the directory where outputs are savedatlas
: the name of the atlas used for the brain parcellation in case of a region-based approachfwhm
: the FWHM value in mm used in thet1-volume
orpet-volume
pipelinemodulated
: a flag to indicate if, when running thet1-volume
pipeline, the image has been modulated or not (on
,off
)acq_label
: label given to the PET acquisition, specifying the tracer used (acq-<acq_label>
)suvr_reference_region
: reference region used to perform intensity normalization (i.e. dividing each voxel of the image by the average uptake in this region) resulting in a standardized uptake value ratio (SUVR) map. It can becerebellumPons
(used for amyloid tracers) orpons
(used for FDG).use_pvc_data
: use PET data with partial value correction (True
/False
). By default, PET data with no PVC are used)precomputed_kernel
: to load the precomputed kernel if it existsmask_zeros
: a flag to indicate if zero-valued voxels should be taken into account for the classification (True
/False
)n_iterations
: number of times a task is repeatedgrid_search_folds
: number of folds to use for the hyper-parameter grid search (e.g. 10)c_range
: range used to select the best value for the C parameter, in the logspacen_threads
: number of threads used if run in paralleltest_size
: percentage (between 0 and 1) representing the size of the test set for each shuffle splitbalanced
: option to balance the weights according to the number of samplespenalty
: type of penalty ("l2" or "l1")
Tip
Usage examples are available in ml_workflows.py
Output¶
Results are saved in the output folder following this hierarchy:
└── <image-type>
├── region_based
| └── atlas-<atlas-id>
| └── <machine-learning-algorithm>
| └── <task1>_vs_<task2>
| ├── classifier
| | └── iteration-<iteration-number>
| | ├── mean_results.tsv
| | ├── results.tsv
| | └── subjects.tsv
| ├── best_parameters.json
| ├── dual_coefficients.txt
| ├── intersect.txt
| ├── support_vector_indices.json
| ├── weights.nii.gz
| └── weights.txt
└── voxel_based
└── smoothing-<fwhm>
├── classifier
| └── iteration-<number-iteration>
| ├── results.tsv
| └── subjects.tsv
├── intersect.txt
├── weights.nii.gz
└── weights.txt
If image_type
is PET
└── <image-type>
└── region_based/voxel_base
└── pvc-<pvc>
Describing this pipeline in your paper¶
Example of paragraph:
These results have been obtained using the machine learning-based classification modules of Clinica [Routier et al; Samper et al., 2018]. Clinica provides a modular way to perform classification based on machine learning by combining different inputs (e.g. gray matter maps obtained from T1-weighted MR images, FDG PET images), algorithms (e.g. support vector machine, logistic regression, random forest) and validation strategies (e.g. K-fold cross validation, repeated K-fold cross validation, repeated hold-out validation). These modules rely on scikit-learn [Pedregosa et al., 2011].
Support¶
- You can use the Clinica Google Group to ask for help!
- Report an issue on GitHub.
