deeplearning-prepare-data - Prepare input data for deep learning with PyTorch
This pipeline prepares images generated by Clinica to be used with the PyTorch deep learning library [Paszke et al., 2019]. Three types of tensors are proposed: 3D images, 3D patches or 2D slices.
Outputs from the t1-linear pipeline and t1-extensive pipeline can be processed (for the moment, latter is available from ClinicaDL. These pipelines are designed as a prerequisite for the deep learning classification algorithms presented in [Wen et al., 2020] and showcased in the AD-DL framework.
Prerequisites
You need to have performed the t1-linear pipeline or t1-extensive pipeline on your T1-weighted MRI. There exists an option to convert custom nifty images into tensors. This option is chosen by adding the parameter custom to the command line instruction and a known suffix, as explained below.
Dependencies
If you installed the core of Clinica, this pipeline needs no further dependencies.
Running the pipeline
The pipeline can be run with the following command line:
clinica run deeplearning-prepare-data <caps_directory> <modality> <tensor_format>
where:
  • caps_directory is the folder containing the results of the t1-linear pipeline and the output of the present command, both in a CAPS hierarchy.
  • modality is the name of the preprocessing done in the original images. It can be t1-linear or t1-extensive. You can chose custom if you want to get a tensor from a custom filename.
  • tensor_format is the format of the extracted tensors. You can choose between image to convert to PyTorch tensor the whole 3D image, patch to extract 3D patches and slice to extract 2D slices from the image.
By default the features are extracted from the cropped image (see the documentation of the t1-linear pipeline). You can deactivate this behaviour with the --use_uncropped_image flag.
Pipeline options if you use patch extraction:
  • --patch_size: patch size. Default value: 50.
  • --stride_size: stride size. Default value: 50.
Pipeline options if you use slice extraction:
  • --slice_direction: slice direction. You can choose between 0 (sagittal plane), 1(coronal plane) or 2 (axial plane). Default value: 0.
  • --slice_mode: slice mode. You can choose between rgb (will save the slice in three identical channels) or single (will save the slice in a single channel). Default value: rgb.
Pipeline options if you use custom modality:
  • --custom_suffix: suffix of the filename that should be converted to the tensor format. The output will be saved into a folder named custom but the processed files will keep their original name. For instance, you can convert the images from the segmentation of the grey matter registered on the Ixi549Space. These images are obtained by running t1-volume pipeline (and SPM underhood). The suffix for these images is graymatter_space-Ixi549Space_modulated-off_probability.nii.gz.
Regarding the default values
When using patch or slice extraction, default values were set according to [Wen et al., 2020].
Note
The arguments common to all Clinica pipelines are described in Interacting with clinica.
Tip
Do not hesitate to type clinica run deeplearning-prepare-data --help to see the full list of parameters.
Outputs
In the following subsections, files with the .pt extension denote tensors in PyTorch format.
The full list of output files can be found in the ClinicA Processed Structure (CAPS) Specification.
Image-based outputs
Results are stored in the following folder of the CAPS hierarchy: subjects/<participant_id>/<session_id>/deeplearning_prepare_data/image_based/t1_linear.
For the t1-linear modality, the main output files are:
  • <source_file>_space-MNI152NLin2009cSym[_desc-Crop]_res-1x1x1_T1w.pt: tensor version of the 3D T1w image registered to the MNI152NLin2009cSym template and optionally cropped.
Corresponding folder and file names are obtained for the files processed with the t1-extensive modality.
For the case of files processed with the custom modality, files are stored in the following folder: subjects/<participant_id>/<session_id>/deeplearning_prepare_data/image/custom.
Patch-based outputs
Results are stored in the following folder of the CAPS hierarchy: subjects/<participant_id>/<session_id>/deeplearning_prepare_data/patch_based/t1_linear.
The main output files are:
  • <source_file>_space-MNI152NLin2009cSym[_desc-Crop]_res-1x1x1_patchsize-<N>_stride-<M>_patch-<i>_T1w.pt: tensor version of the <i>-th 3D isotropic patch of size <N> with a stride of <M>. Each patch is extracted from the T1w image registered to the MNI152NLin2009cSym template and optionally cropped.
Slice-based outputs
Results are stored in the following folder of the CAPS hierarchy: subjects/<participant_id>/<session_id>/deeplearning_prepare_data/slice_based/t1_linear.
  • <source_file>_space-MNI152NLin2009cSym[_desc-Crop]_res-1x1x1_axis-{sag|cor|axi}_channel-{single|rgb}_T1w.pt: tensor version of the <i>-th 2D slice in sagittal, coronal or axial plane using three identical channels (rgb) or one channel (single). Each slice is extracted from the T1w image registered to the MNI152NLin2009cSym template and optionally cropped.
Going further
Describing this pipeline in your paper
Example of paragraph
These results have been obtained using the deeplearning-prepare-data pipeline of Clinica [Routier et al; Wen et al., 2020]. More precisely,
  • 3D images
  • 3D patches with patch size of <patch_size> and stride size of <stride_size>
  • 2D slices in {sagittal | coronal | axial} plane and saved in {three identical channels | a single channel}
were extracted and converted to PyTorch tensors [Paszke et al., 2019].
Tip
Easily access the papers cited on this page on Zotero.
